Primary Clutch Removal
Old Nov 16, 2004 | 09:12 AM
Leaf's Avatar
Default Primary Clutch Removal
My clutch won't come off!
I'm using the puller with the impact and following instruction right out of the service manual.
Anyone have any ideas?
Old Nov 16, 2004 | 10:28 AM
Guest
Guest
Posts: n/a
Try this. Put a jack under the clutch side of the quad & lift it up about a foot.
With your clutch bolt out, pour about an ounce or 2 of oil inside. Put some plumbers
tape on the threads of the puller & hit it with the impact gun again. Should hydraulic
right off.
Old Nov 17, 2004 | 02:04 PM
Leaf's Avatar
Thanks sledman8002002.....I tried it an I can tell the oil was working because the puller wasn't threading in as deep as dry, but it didn't come off.
It's on tight! [img]i/expressions/face-icon-small-mad.gif[/img]
Anyone else have ideas?
Old Nov 17, 2004 | 05:56 PM
Bear4570's Avatar
Have you tried the "don't force it get a bigger hammer" remover? That's where you get the puller pulled down tight and then whack the remover center bolt with a hammer. Oh yeah, don't use the oil because you don't want any shock absorber effect.
Old Nov 17, 2004 | 09:12 PM
Guest
Guest
Posts: n/a
It's Ok to hammer the puller if you plan on tearing the motor down. I've done it many times, but it'll almost always knock the crank out of whack. You'll fix one problem, but create another when you find a new vibration in your handlebars or in your seat.
If your impact won't do it, borrow a stronger one, (I'm assumming it's a 1/2" drive), or use a persuader on a ratchet. They almost always come off with a crack/bang, so be prepared.
Old Nov 17, 2004 | 09:16 PM
Guest
Guest
Posts: n/a
Or, some heat from a propane torch right where you figure the shaft is mated to the clutch. Hard to explain, put the heat to the center of the fixed sheave in the spot where the belt would sit at idle.
Old Nov 18, 2004 | 01:20 AM
Bear4570's Avatar
You don't hit it like you are trying to drive the shaft out the other side. Give it a sharp rap, it is the sudden impact that knocks it loose, not power.
Old Nov 18, 2004 | 07:04 AM
Guest
Guest
Posts: n/a
Have at it then.
Old Nov 19, 2004 | 12:25 AM
weez440's Avatar
bear is right it seems like just a slight lil vibration from tapping it a lil with a hammer does the trick then tighten and hit it again but like said not to hard just a lil rasp and always keeping tention on the clutch puller some of them can be very very difficult to get off so good luck
Old Nov 19, 2004 | 08:38 AM
Leaf's Avatar
Well, tried everything with no results!
Decided to run the belt over the secondary instead. I had two 1mm shims in there, so I removed a 1mm shim and added a .3 mm shim which gave me a belt tension at 24mm+.
Should be good-to-go!
Thanks for the help.
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
