AC 400 manual -light problem
Old Nov 28, 2004 | 01:49 PM
Alff's Avatar
Default AC 400 manual -light problem
This is a 2004 machine.Sometimes the lights work,sometimes they dont and usuallly the tachometer doesnt work at the same time.
Do you think this could be a loose or defective fuse or some other problem?
Thanks
Old Nov 28, 2004 | 09:21 PM
Bear4570's Avatar
It's probaly either a loose connection or a fuse problem. The fuse holder could be not tight enough on the blades of the fuse or the wire connectors on the fuse holders themself. Sometimes just pulling the connector off and push it back on will fix this kinda thing, same with the fuse holder. They get a little dirty or a bit of corrosion and all they need is the friction of off and on to fix it. Then again it could be the switch.
GregM
Mar 6, 2018 06:53 AM
Captjay
Jul 23, 2015 12:33 PM
Scottma518
Jul 16, 2015 09:19 PM
toonces
Jul 15, 2015 07:14 AM
tricky123
Jul 12, 2015 05:51 AM
