Ride Adjustment
Old Dec 7, 2004 | 11:32 AM
oregoner's Avatar
Default Ride Adjustment
I have an 03, AC500i and have yet to be able to move the adjustment on the shocks. Straight out of the box I broke the wonderful cast spanner that came with the rig. Bought a steel one and they still will not budge. Is there something I'm missing. Need some input.
Old Dec 7, 2004 | 01:28 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
I too have yet to try it, but they say that if you jack the ATV up so the front tires are off the ground it is a lot easier. Give it a shot. Good luck!
Old Dec 7, 2004 | 02:15 PM
cFhDimebag's Avatar
Just spray a little WD-40 on it and use 2 hands. It worked for me, even with the cheesy tool they gave me.
Old Dec 7, 2004 | 02:53 PM
JimJa's Avatar
Oregoner,
Where did you get the "steel spanner" for shock adjustment? You are right, the OEM unit is cheezy and having one more substantial would be a good thing. I haven't broken mine yet, but bent it significantly. The WD-40 is a good suggestion. Soak each shock and add a little grease on the "notches" of the adjustment.
Jim
Old Dec 7, 2004 | 02:58 PM
1wook's Avatar
Squirt them down with wd-40, jack the wheeler up, grab them with a channel locks, the'll turn easy.
Oregoner, if you post your email I'll send you some pics of my 04 fender flares. I put one in my pictures today, should be approved soon.
Old Dec 7, 2004 | 07:21 PM
oregoner's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img] Thanks a Million for the ideas, will give it another try. I got the spanner at a local tool supply house.
Old Dec 7, 2004 | 07:56 PM
DanW's Avatar
The WD40 idea and taking the weight off the shock are the best ideas and it works. The first time I adjusted mine, I used water and took the wieght off. I also held the wrench tightly as close to the working end as I could get so as not to have leverage break the handle.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Joe04785
Jun 15, 2015 03:12 AM
DOAinNY
Jun 11, 2015 10:34 PM
cornermike
Jun 3, 2015 07:27 AM
Jiggypete
May 30, 2015 07:55 AM
