winch problems
Old Jun 17, 2005 | 10:15 PM
weez440's Avatar
Default winch problems
ok when i have been winching for a while and the battery starts to get a lil drained my atv will not run at all. i hit the in button and keep the motor reved up and it just dies the second i hit the switch but when the battery gets charged up it works fine. any ideas? trying to winch out a blazer and it was bothering me lol look at my pics.
Old Jun 18, 2005 | 02:33 AM
Bear4570's Avatar
Either your charging systems is weak or the winch is drawing more amps than your battery and charging system can cover. My first choice would be the charging system is weak. Most likely is a diode in the rectifier is blown or the regulator is bad. Then again it could be a weak stator (charge coil), but this is least likely. If the winch is over amping, the motor is bad or there is a loose or dirty or corroded connection.
Old Jun 19, 2005 | 12:43 AM
ridinsmooth's Avatar
get a new battery that can take the winch.
Old Jun 19, 2005 | 01:10 AM
weez440's Avatar
thanx for the idea's guys i think first i am gonna try just cleaning all the connections.
toonces
Oct 19, 2015 02:21 AM
user493
Aug 13, 2015 12:54 PM
Bratman2
Jul 23, 2015 12:36 PM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
