Horn for Cat wiring question?
Want to put a horn on the cat. I ordered a kill/horn button from rocky mountain, but when I got it in, it only has one wire going to it. How to you complete the circuit for the horn with just one switch from the button. Anybody know how you do this? I figure its not too hard but I just cant picture it. Thanks for the helpl.
Is there one switch or two? If there is only one I would suspect the switch grounds thru it's mount and the wire goes to the ground side of the horn and you will have accessory plus 12 volts to the horn all the time. When you press the button you complete the circuit.
