650 oil capacity
Old Dec 14, 2005 | 09:25 PM
z44h2o's Avatar
Default 650 oil capacity
Just changed the oil on my 650 using the artic cat synthetic kit. the manual says it takes 1.85 qt. I did that ran the engine a bit and its still on the add mark. I put the rest in which was hardly any and drove it around the yard a bit, I let it sit for an hour and it is eighth inch past the add mark. anybody else run into this?
thanks
Old Dec 15, 2005 | 09:11 AM
Theshonk's Avatar
thanks
Yes been there done that the manual is incorrect. Two quarts with filter change will put you midway (1/2 +-) mark. You do not want the level at the top (full) mark. Because you will get oil “blow by” into the air box.
Shonk
Old Dec 15, 2005 | 08:00 PM
z44h2o's Avatar
Thanks shonk, This is the second oil change I put on the beast at 225. I bought her last spring, i heard that people were putting to much oil in causing a problem. I Think they need different dipsticks.
Thanks a bunch
p.s. Boy can she push the snow
Old Dec 16, 2005 | 09:44 AM
Theshonk's Avatar
Thanks a bunch
I bought my V2650 last spring also. The oil gets changed every 500 miles max
I don’t push snow with my AC that’s for my JD AR (1948)
Shonk
Ps I have 2,800 miles on the V2650 with no major issues
Old Dec 17, 2005 | 09:48 AM
sammydogs64's Avatar
The Shonk is correct, if you are at or above the full mark, drain a little out.
gogogo
Oct 15, 2015 05:40 PM
antiguogrumete
Sep 5, 2015 03:41 AM
cstark
Sep 11, 1999 01:21 AM
