squealing when left in gear(duramatic)
Old Jan 22, 2006 | 10:57 PM
kevinator's Avatar
Default squealing when left in gear(duramatic)
on my 04 650, there is a squeal when left in gear and idling when the machine is fully warmed up. The squealing goes away when revved up to engagement or shifted into neutral, any ideas?
Old Jan 23, 2006 | 12:16 AM
gtdoctor's Avatar
The squeeling in gear when stopped is your belt contacting the moving primary clutch. This'll sound strange if you haven't heard it before, but the squeeling is a good thing because it means that your belt is on the tight side of the deflection specs, which is very important for long belt life on the 650 V2. I would leave it as it is unless you develop any other problems.
Old Jan 23, 2006 | 12:42 AM
kevinator's Avatar
Is the belt not in contact with the primary clutch when it is also on neutral? If that is the case why does it only squeal when it is in gear,in both high and low ratios.
Old Jan 23, 2006 | 10:12 AM
TORK's Avatar
When you are in gear your driven clutch is held still by the tires and the rest of the driveline. When trans is in neutral your driven clutch is allowed to turn so there is no squeal.
Old Jan 23, 2006 | 10:14 AM
TORK's Avatar
By the way, if your 650 is the V-Twin engine that is not the Duramatic .
Old Jan 23, 2006 | 07:15 PM
kevinator's Avatar
thank you guys for your help.I understand what you are saying and now it makes sense to me.
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
djoshuah
Aug 5, 2015 10:59 AM
micheleLeigh
Technical and How-To Articles
Jul 19, 2015 07:32 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
