H1 SE Powerful Enough?
Old Feb 10, 2006 | 01:15 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Default H1 SE Powerful Enough?
Originally posted by: ALGRIZZ
I'm the friend that jjonjon was talking about i never said that the H1 didnt lose power. I said that my dads H1 could run 29.5's stock and turn them over preety godd compared to any other stock atv. it will still do donuts, spin out and turn the tires over in the thick stuff.
so I'm not full of shyt.
Welcome! Right on, the H1 has plenty of room for 29.5's.
Old Feb 10, 2006 | 11:09 AM
700vtwinman's Avatar
The ACH1 or ACV2 both have plenty of room for the outlaws 29.5 tires. And, the motor should have no problem turning the tires. Yes, it will probably take off some of the top end speed, but the low and mid range should be just fine. Remember years ago when a 500cc machine was the largest and people put 27's on them and they turned fine? But, since the AC's have the most ground clearance, I would probably put on 27's.
Old Feb 12, 2006 | 07:36 AM
2c3's Avatar
2c3
ive seen 2 h1 and 1 h2 with 29.5s stock. they will fit and they will spin them in the thick stuff
Old Feb 12, 2006 | 01:10 PM
99MudKing's Avatar
The H1 engine makes tons of low end grunt, and the low range on that machine is nuts!!! It'll turn 29.5 outlaws like no other big bore, even the 750s, and with NO belt problems.... the duramatic trans is built that good.
It's not a speed demon, but it'll pull a house off it's foundation in low range.
Old Feb 12, 2006 | 01:28 PM
  #15
v2rider's Avatar
I agree that the low range in the h1 is superb, but I think if the v2 had the same type low range it also would be as, if not a little more powerful than the duramatic. Oh well, mabey they will change something later to make it lower in low gear. Alot of people say "I dont think its right that you can go 55mph in low range" I dont mind though.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
