300 shift linkage for 2wd, 4wd and lock-how I did it.
Old Nov 23, 2000 | 06:29 PM
bahnerman's Avatar
For those of you who are still wondering if it is possible to make your 300 have all three positions- IT IS! I tried to adjust the existing linkage without any luck. I succeeded in the goal by cutting the shifting rod and lengthening it by 1 1/2" and doing a little rebending. It works fine so far. The stock rod is 5/16" diameter. I purchased a piece of pipe that was 5/16" inside diameter, cut the rod and then cut a piece of the pipe 3" long and spliced the rod so it is now longer than original. The handle does stick out about an inch farther than stock in 2wd and 4wd and flat against the fender while locked. I don't think it will get in the way and if it does get bumped while riding it will go forward and not bounce you out of 4wd at the "TOTALLY" wrong moment. Hope this helps those of you who have been thinking of doing the same to your front ends.
95wolv
Sep 27, 2024 12:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
