venom winch v-2 650
Old Jun 13, 2006 | 09:32 PM
hokster's Avatar
Default venom winch v-2 650
i would like to install my new winch, does anyone have any tips on best ways to run wiring or mounting contactor switch ?
Old Jun 13, 2006 | 10:42 PM
sevenmag's Avatar
I put a warn winch on my 06 400 auto. I put the contactor under the seat. Basically right where your crouch would sit on the seat on the 400 there is a nice flat piece of steel. I drilled 4 holes and ran the wires along the frame and wire tied them. AC has mounting holes along the oil cooler bracket but I wouldn't want my contactor getting buried in the mud and under water.
Old Jun 14, 2006 | 07:12 PM
v2rider's Avatar
I have the same winch, and he is right. Mount it under the seat, about half under the "glove box". I didnt drill holes, i just ty wrapped it and it holds fine. Just run the wires olongside the airbox, by removing the glove box, and down to the winch.
Old Jun 15, 2006 | 09:31 PM
sammydogs64's Avatar
I installed a Venom as well, I highly reccommend disasembling it and greesing the heck out of it. I had mine installed for a month and after the second time I used it, it was binding up, the greese was hard inside.
Old Jun 16, 2006 | 11:10 PM
rango726's Avatar
sammy i just had the same problem today my venom winch just bound up just out of the blue and the grease was all dry like it had been used for 20 yrs but now whenever i try to wind it up it makes my cat shut off ??? and it wont wind up any clues as to what that might be
Old Jun 17, 2006 | 02:03 PM
Mine did the same thing, it would kill the engine when I tried using it. I had to completely disasemble grease the gear boxes and clean the brushes on the motor.
Old Jun 17, 2006 | 06:39 PM
v2rider's Avatar
What type of grease are you using, and is it a pain in the as* to do the job?
Old Jun 18, 2006 | 10:33 AM
Four bolts, get area and a couple of clean rags, be carefull and take your time. I cleaned the brushes first, then pulled apart the two gear packs and just covered them in lithium grease.
Old Jun 18, 2006 | 10:34 AM
Old Jun 18, 2006 | 11:19 AM
v2rider's Avatar
thanks, now i have a little project for another afternoon.
Johnny Mac
Aug 15, 2019 03:13 PM
salixair
Nov 3, 2015 08:25 AM
cboler9
Sep 24, 2015 08:35 PM
ylomnstr
Sep 10, 2015 06:45 AM
chewy78
Sep 8, 2015 10:37 AM
