650 more help
Old Jul 21, 2006 | 08:39 PM
v2rider's Avatar
Default 650 more help
Originally posted by: acpower
well if you take yours over 30 in low gear often you may have effed something up. L is for 0-30 and H is for 30+. hope you didnt ruin it.
I take mine to 50 in low everytime i ride it, that wont hurt anything if you dont hold it tached out for a long time. Its actually better for your belt. Of course,, this whole speech is good for the V2 only.
Old Jul 27, 2006 | 10:55 AM
Sput's Avatar
Well I went to change the jets last night and when I pulled the bowl drain screw out of the back carb I got maube 5 drops of fuel. I did not measure the front one but it seemed like the correct amount for the bowl. Turned the key on, got a stream of fuel. Removed the bowl and float, checked again for blockage, all clear. Adjusted the float a little, reassembled, fired up and idled, removed drain screw, again 5-6 drops. Front one was fine. This is where it gets weird, idled again, removed rear drain, lots of fuel, front one 5-6 drops. Any ideas? Thanks..
