dead
Old Sep 1, 2006 | 03:08 AM
ArcticCatEd's Avatar
Default dead
I have a 2003 AC standard. It was running one day loaded it on the trailer and the problem is now it want crank. It want to anything. The lights or and thing will not work. But the winch does so I know it's not the batt. Anyone have any ideas? I am lost on it[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 1, 2006 | 09:54 AM
v2rider's Avatar
Default dead
Kill switch mabey?
Old Sep 1, 2006 | 11:11 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Default dead
Or a fuse. Must be that
Old Sep 1, 2006 | 08:25 PM
Bear4570's Avatar
Default dead
Clean all the battery cable connections (both ends, for sure the grounds). The winch has it's own battery wires seperate and make sure the fuse holders and ends of the fuses are clean.
Old Sep 1, 2006 | 08:32 PM
Default dead
I have checked all the fuses and the batt cables are clean. I can take a jumper wire and jump from the batt. to the ign. fuse and it will crank when you push the button. The key switch will notcut it off but when you take the jumper off it dies? Thanks for all the help so far. Anymore thoughts on this problem
Eddie
Old Sep 3, 2006 | 09:40 PM
GreenAC4004x4's Avatar
Default dead
You need to get an amp meter with a continuity test or a test light (sold at any auto parts store)...start at your ignition switch with the test light and back probe the wires with the key on...then move to the kill switch do the same thing... sounds like you have a dead short in the wiring harness.
Old Sep 5, 2006 | 10:41 AM
TORK's Avatar
Default dead
Check the fuse at the solinoid. That is your main feed for machine. This sounds like the reason for your problem but then you need to find out why you blew a 30 amp fuse.
pgamboa
Dec 24, 2023 11:52 AM
slowgsxr97
Mar 18, 2022 03:40 AM
DM2015
Sep 7, 2015 10:36 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Hondamx751
Aug 13, 2015 01:06 AM
