Outlaw radials...Opinions please...
Old Sep 27, 2006 | 05:49 PM
RobAlford's Avatar
Default Outlaw radials...Opinions please...
Anybody have the outlaw radials? Are they good or bad? Are they heavy? Thinking about a set for my Arctic Cat 500 in the 27x9.5-12 all the way around. What is the actual measured width? Thanks for your help, Rob
Old Sep 27, 2006 | 07:10 PM
weez440's Avatar
radials might be good for some atv's but beings the cat is a larger machine i personally like the stiff sidewalls of a 6-ply less body roll. and i wouldn't go any bigger then 26's on a 500. that is just my 2 cents worth you may love them.
Old Sep 27, 2006 | 09:24 PM
v2rider's Avatar
I agree with Weez. I would not go bigger than 26" either. Look at my Swamplites, they are a good All Terrain Tire, and they are 6ply. The Outlaws are supposed to be good tires also. Good luck!
Old Sep 28, 2006 | 12:48 AM
RobAlford's Avatar
The Outlaw radials that I'm looking at are 27x9.5. If I get 26's I'll probbly go with 12 wide on all corners. I have a set of '05 aluminum AC wheels that I'm fitting on my 2000. These rims are 12x6 so I want to use the same width on all four corners. Which way should I go. I want a square footprint, it seems like most 12x10's are rounded(less tread depth on edges) to be used as front tires.
Old Sep 28, 2006 | 07:39 PM
weez440's Avatar
i would go with a lil narrower on the front for handling purposes even an inch or two.
BYC
Sep 25, 2015 02:10 PM
1000gade
Sep 9, 2015 03:35 PM
poutlaw525
Sep 9, 2015 03:19 AM
1000gade
Aug 19, 2015 07:10 PM
Andy Bassham
Jun 30, 2000 12:31 AM
