Cant keep Tire on.
Old Nov 28, 2006 | 05:44 AM
timberkiller07's Avatar
Default Cant keep Tire on.
I recently had to replace a axle on my 05 500 4x4 and i went with the gorilla axle. i only have one problem i dont know what the spec is for the spindle nut. the first time i just got it snug and after a while of riding it backed off and ruint the nut. i just purchased a new hub, rotor and spindle nut and was wonderig if anyone knew the spec for the spindle nut.
thanks for your time
Shane
Old Nov 28, 2006 | 11:04 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
If my memory serves it is 70 pounds. How did that happen, did it brake off the kotter pin too?
Old Nov 28, 2006 | 03:59 PM
Yes i think i didnt get it tight enough when i did it the first time and it was wobblin and broke the carter pin. and it messed up the thread on the nut so i tried to find a nut that would fit at a local autoparts store. Since i was out of town riding at a park and i had paid 50 bucks to ride for five minutes i was pretty determind to get my 50 bucks out of it.. lol
that is 70 inch pounds?
Old Nov 29, 2006 | 06:47 PM
swampyjunior's Avatar
I do not use the torque specs here.
I tighten the nut until the tire will not spin freely without dragging, then I back the nut off to the next notch that allows me to put the pin through. Doing this as long long a I do not reuse the pins, I hve not had any problems. If you reused the pin it could have sheared off from being bent/rebent and allowed the nut to back off some. Reusing the pins is not a good idea especially since they are so cheap.
If you purchased a new hub did you install new race and bearings in the hub? If race/bearings are bad you should not reuse them either?
Old Nov 29, 2006 | 08:59 PM
Thanks for the feed back. Thats probably what happend because i did reuse the pin. I know better now. i orderd alot of them with my hub. the bearing and race are still good. I am going home this weekend to work on it so i will let yall know how it goes
thanks
Shane
Old Nov 29, 2006 | 09:02 PM
LittleBill's Avatar
the pin is not the reason, you had the issue, i have reused axle pins on everything from cars to buses with 0 problems, there is no huge amount of torque on them hell half the time the pin isn't even touching the castle nut, i would look closer, the cotter pin is not your issue
Old Nov 29, 2006 | 09:42 PM
well what do you think the problem is?
Old Nov 29, 2006 | 10:30 PM
Bear4570's Avatar
The shop Manual says that it is 75 ft/lbs front and rear for the 400 and 500 manuals. But 75 ft/lbs for the front and 125 ft/lbs on the rear for the 400, 500 Autos and the 650 H1 and the V-2. Which does make a lot of sense but hey what do I know.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
