04 650 V2...How much oil?
Old Feb 15, 2007 | 07:50 AM
HelloNewman's Avatar
Default 04 650 V2...How much oil?
I've lost my owners manual and I need to change my oil, I don't remember how many quarts it takes with a filter...I thought 3 but want to make sure...Thanks
Never mind, I found the information. 2.17 Quarts with a filter, so that's about 2 1/8 I guess.
Old Feb 15, 2007 | 01:50 PM
sevenmag's Avatar
I believe my owners manual says 1.8 quarts 06 650 v2
Old Feb 15, 2007 | 03:06 PM
Williebee's Avatar
My 2006 Operator's manual has: Engine oil capacity at 1.7 L (1.85 U.S. qt ) .........williebee
Old Feb 15, 2007 | 05:44 PM
oledad's Avatar
Yes its a little less than 2 qts. 2 qts is all that come with the arctic cat 04-06 v2 oil change kits.
Old Feb 15, 2007 | 11:22 PM
I did the oil change and started out at 1.75 quarts and went from there...all the way up to about 2 1/8 quarts. I did use a little bit larger filter than it calls for but not much larger, maybe a 1/4 inch which to me would equal less than an 1/8 quart on that small diameter filter. The oil still wasn't to the "H" (Full) on the dipstick, and yes I'm screwing the stick all the way in.
Old Feb 16, 2007 | 04:17 PM
oledad's Avatar
To much oil, are you letting it sit for 10-20 minutes after stoping to check, if not it just hasn't all drained back. If it took more than 2 qts there would be 3 qts in a v2 oil change kit pure and simple. They are not going to under fill it and cause possible engine damage. By overfilling you are running up the oil pressure and you could end up with blown seals or gaskets.
Old Feb 16, 2007 | 07:49 PM
Well here's the deal, the ATV has been sitting overnight and the level on the dipstick is STILL below the full mark, you can do whatever you want with that information. The only indication I have as to how much oil the engine wants is the dipstick and it says all is well.
Here's what the 2004 650 V-2 service manual says;
"Install the engine drain plug and tighten to 2.0
kg-m (14.5 ft-lb). Pour 2.05 L (2.17 U.S. qt) of the
recommended oil in the filler hole. Install the oil
level stick/filler plug"
Old Feb 17, 2007 | 04:16 AM
v2rider's Avatar
You dont want the oil to the "full" mark. Leave it between 3/4 and full, or you will have oil blow into your filter
Old Feb 18, 2007 | 04:28 AM
TRVRider's Avatar
I just can't resist....
Add oil Till it's full.
Old Feb 18, 2007 | 09:20 AM
I did[img]i/expressions/face-icon-small-smile.gif[/img]
