Thoughts on Tires
Old May 9, 2007 | 03:41 PM
swampyjunior's Avatar
Default Thoughts on Tires
AC rims are 4/115
4bolt, 115mm aprart I believe.
I painted my stock steel rims black a few years ago. Holding up pretty well. Just picked up my 3rd set of Mudlites. 26inch, 26x9x12 front 26x10x12 rear for $228.
I like the look of the ITP C-series but I Think they are aluminum and I prefer steel.
SJ
Old May 10, 2007 | 12:18 AM
KY06AC500AUTO's Avatar
The bolt pattern is 4 on 115 and the offset is 5+2. Remember when ordering wheels your rear suspension makes a different. If you have an irs it takes the same wheel front and back but with a straight rear axle it takes different wheels. I was going to order some ITP wheels for my 06 500i auto but ITP wheels make you atv 1 inch wider on each corner.My 500 is already 47.8 inches wide and I'm not sure I want it any wider, It would make the trails pretty tight in the woods. I hope this helps you.
Bratman2
Aug 6, 2022 01:42 AM
firsttimerider
3) General Discussions..
Aug 9, 2015 09:54 AM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
