06 Arctic Cat 500 Auto - Weak starting - battery OK
Old Nov 4, 2007 | 02:40 PM
cg5356's Avatar
Default 06 Arctic Cat 500 Auto - Weak starting - battery OK
Starter weak when ATV is cold. Battery tested OK @ 12.1v. When ATV is run a bit, starter works fine. Cleaned battery connections HELP!!
Old Nov 5, 2007 | 08:37 AM
v2rider's Avatar
A battery with higher cca would be my choice here.
Old Nov 5, 2007 | 01:17 PM
Jetmech's Avatar
Try to remove the battery and put a good top charge on it, you may already know this, but just because you show 12.1 volts doesn't mean that you have the correct amperage under load. The reason that it starts good after you ride it for a while is because the atv top charges the battery and increases the amps. If the charge doesn't work, then I would take v2riders advice and go after a new battery. I hope this helps.
Old Nov 5, 2007 | 01:42 PM
Junkman673's Avatar
12.1v under a load? Or 12.1V static? I've seen many batteries that will say 12V or higher with a volt tester but will drop to almost nothing as soon as you put aload on it.
Your battery is probably shot. Replace it. It's a cheap easy fix.
chinkapin
Jul 14, 2016 06:58 AM
1000gade
May 27, 2015 12:37 PM
hammer4
Sep 14, 2000 07:43 PM
hammer4
Sep 13, 2000 12:52 PM
tb
Jan 31, 2000 11:16 AM
