rear tire alignment toed-in
Old Apr 12, 2008 | 08:39 PM
dirtmonkey's Avatar
Default rear tire alignment toed-in
I've got an '08 AC500. Love the bike and it seems to handle fine, but standing behind it the rear tires are aligned so that they visibly toe-in. Looks kinda strange, ... is this normal ?
Thx/- Steve
Old Apr 13, 2008 | 11:08 AM
mudslinginfool's Avatar
Does it in the Mud!
if they toe in on the bottom if your shocks are adjusted to the hardest setting.then yes its normal because once you sit on the bike or put some weight on the rear rack it will straighten up. also when you give it gas the weight shifts to the rear and they will straight out. it may also appear this way
Old Apr 13, 2008 | 11:19 AM
Does it in the Mud!
<div class="FTQUOTE"><begin quote>Originally posted by: mudslinginfool
if they toe in on the bottom then yes its normal because once you sit on the bike or put some weight on the rear rack it will straighten up. also when you give it gas the weight shifts to the rear and they will straight out. it may also appear this way if your shocks are adjusted to the hardest setting. picture it this way. on an idependant suspension if the wheels were aligned straight with no wieght, then you get on and maybe with some gear on the racks and you ride all day long, the tires would toe out allowing the tires to wear on the inside of the tire instead of the center where all your main tread and traction is.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Polaris5
Aug 29, 2015 09:11 PM
rcappie4
Jul 18, 2015 07:51 AM
rcappie4
Jul 10, 2015 04:54 PM
