Thunder cat 1000
Old Nov 18, 2008 | 09:17 PM
  #41
T-CAT Spd's Avatar
Default Thunder cat 1000
Do you find any issues or with your spike load dampener? I do agree with 100% about the electronic diff lock. My 08 had several problems as well but agree again that the 09 models are very solid and reliable.
Old Nov 18, 2008 | 09:33 PM
  #42
oldpepsiman's Avatar
did you trade in your 08? if so how much did they give ya. so out the door what did it cost you to trade a year newer? so far i've had no problems but i've only got 250 miles on mine
Old Nov 18, 2008 | 09:40 PM
  #43
Default Thunder cat 1000"></title><script src=
to bad i can't think of everything on one thread, called speedwerxs today. ask if i would be doing the clutch install. said no i'd probably have it done he said even though it's more he would go with the slip on until i had time to play with the clutch. right now i'm undecided.
Old Nov 19, 2008 | 07:33 AM
  #44
T-CAT Spd's Avatar
No I didn't trade my 08 reason being I wanted to recover as much money as possible. I got 10,000 for my 08 but that's Canadian. As far as the speedwerx add on's I still think the clucth kit will serve you better to start and it's only half the price. 09 T-CAT.
Old Nov 19, 2008 | 07:47 PM
  #45
thanks!! i'm still going to do somemore research. can't makeup my mind.
Old Dec 3, 2008 | 07:48 PM
  #46
DrewSimmons's Avatar
i have a thundercat on 32 silverbacks it turns them great but the clutch rear end that they put in slipps so i had to weld it together never broke a belt you break belts if you dont have a enough power
Old Dec 3, 2008 | 07:56 PM
  #47
tsking my tcat to a specialty shop to run a dyno on it and fine tune it. this shop does all types of bikes as well as cluth kits-turbo-nos all the go fast stuff. i'm not doing any mudding just sand. thanks for the info
Old Dec 3, 2008 | 08:07 PM
  #48
i welded it up but be careful i broke the weld but welded it again i have 32 silverback
Old Dec 3, 2008 | 08:19 PM
  #49
T-CAT Spd's Avatar
Hey Drewsimmons how difficult was it to weld the diff? The problem is down here that no one really knows how to do it. I would be happy to do it cause my dealer told me he would figure a way to help me warranty wise. 09 T-CAT
Old Dec 4, 2008 | 11:52 PM
  #50
tcat on highlifter.com artic cat fourm has pictues and directions for welding the spike load dampner fix this is the thread tittle also.
