AC Handling
Old Jun 13, 2008 | 08:40 AM
mitchetr's Avatar
Default AC Handling
I have a 2004 AC 400 4X4. Lately I have found that when riding in 2 wheel drive the front end does not handle good at all. It shakes and pull when riding down the road. But when I put it in 4 wheel all is fine. Any suggestions?
Thanks
Old Jun 14, 2008 | 03:09 AM
rango726's Avatar
Default AC Handling
hows your alignment. toe and camber???? check it all out. or check your tire pressure. all of these will cause handling issues
Old Jun 14, 2008 | 07:35 PM
buckaroo50's Avatar
Default AC Handling
In addition to what 'rango726' said. Make sure your rear suspension is stiffer than the front suspension. You get stability from the rear not the front. If the front is stiffer it will handle like you have a flat tire in the rear and will get squirrely. Check for looseness in the front end; bushings, wheel bearings etc.
Also check out the link below for some handling tips.
http://forums.atvconnection.co...ke%20the%20ac%20handle
Old Jun 14, 2008 | 08:07 PM
mitchetr's Avatar
Default AC Handling
Thanks guys I will take a look at this and let you know.
dannytas
Sep 26, 2017 06:31 PM
badgerboy1
Sep 26, 2017 06:11 PM
Levi Enstad
Sep 26, 2015 08:00 AM
Jason Campbell
Sep 7, 2015 02:25 PM
