What engine oil for diesel AC?
Old Aug 14, 2008 | 08:56 PM
Crazyotto1's Avatar
Default What engine oil for diesel AC?
Looking to see if anyone know what type of oil the AC diesel 800 quad requires and how much I will need for an oil change? Thanks
Old Aug 14, 2008 | 09:07 PM
DODGE57HEMI's Avatar
Mopar Man!
Good luck for a answer on these forms as not to many people here have them! You prob do better with a answer from the dealer!
Old Aug 16, 2008 | 03:41 PM
BlueRubie's Avatar
5w-40 european diesel formula about 4qts !
you can use a 15w-40/15w-50 but it must be a synthetic oil. . .
5W-40 Amsoil.
15W-40 Amsoil.
15W-50 Mobile 1.
I would use 5w-40 Amsoil ! but any 5w-40 will work !
Mike D
Old Aug 17, 2008 | 09:38 PM
HeftyLefty's Avatar
You can download a service manual here.
http://www.snowbuzzard.com/acmanuals/
Old Aug 19, 2008 | 04:16 PM
sdbowhunter's Avatar
I own a 08 700 diesel and the manual says to use 10W-40 down to 30 degrees and below 30 to use 0W-40. The manual says to put in 2.1 quarts, but this won't fill it up to the full line. I usually put 2 quarts 8 ounces and it is right at the full line. I either use Amsoil 10W-40 high performance oil or 10W-40 Royal Purple in mine.
Old Aug 20, 2008 | 08:08 PM
elk county dutch's Avatar
Hi everyone! Newbie here on this forum, but have many miles and hours ATVing in the last 12 years. Exactly a month ago I bought a new 2007 year 700 diesel. I changed oil at 200 miles and 30 hours. The parts man at Arctic Cat dealer called the head office and they told him any good 10 W 40 would be fine, but personally indicated that a diesel type oil would be best. I decided to go with 5 W 40 Rotella Synthetic. And as was posted earlier, 2.1 quarts doesn't bring the dipstick up the top mark. On my machine it is in the middle of add and full.
The air filter is a nightmare to try to get out. There is just not enough room to clear everything from what I can see so far.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
