posi front end trick
Old Sep 16, 2008 | 12:02 AM
mountainclimber's Avatar
Default posi front end trick
I heard somewherethat if you disconnect the shift rod linkage at the front differental that if you push it more forward than the original lever would it will turn the front end posi... has anyone else heard of this trick? iTs a 2003 400
Old Sep 25, 2008 | 10:22 AM
is there any tricks for making these front ends posi
Old Sep 25, 2008 | 12:04 PM
mudslinginfool's Avatar
Does it in the Mud!
i believe it was the eirlier 300s. 98-2000 i think, maybe to 2002. i had a 99 and found that out after i got rid of it so i never found out for sure. the 400 and 500s may have also but i only heard of the 300s having that
Old Sep 25, 2008 | 12:17 PM
TLC's Avatar
TLC
Another trick is to used the front brake to fool the limited slip front ends to throw power back and fourth to each front wheel, therefore applying power to the wheel than needs it for short periods.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
