AC 06 auto 500 belt problems
Old Nov 6, 2008 | 12:31 PM
arcticman69's Avatar
Default AC 06 auto 500 belt problems
Has anyone had any problems with oil in there clutch cover? mine is leaking oil bad and was just wondering if this is a common problem. Thanks
Old Nov 6, 2008 | 08:17 PM
swampyjunior's Avatar
I have not had this issue but I have read about some guys having a seal leak inside the belt cover. I am not sure how common it is.
sj
Old Nov 7, 2008 | 09:49 AM
I kind of figured that but i wasn't able to find a seal under any parts diagrams i searched i'll have to keep looking
Old Nov 7, 2008 | 02:40 PM
HeftyLefty's Avatar
It's the shaft seal that's leaking, it's weeping oil into the clutch cover area from behind the pulley. Pull the back over the cover off, and you should see oil.
Old Nov 8, 2008 | 08:37 AM
i think i got it. it was the nut on the outside of the drive clutch it came loose and was causing it to leak oil from the shaft seal. i talked to my dealer and he said he had recalls on 04 and 05 for this nut but not the 06's apparently there was a problem with mine because after i tightend this nut it stoppped leaking.
Old Mar 12, 2009 | 08:57 AM
UGLY88's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: arcticman69
i think i got it. it was the nut on the outside of the drive clutch it came loose and was causing it to leak oil from the shaft seal. i talked to my dealer and he said he had recalls on 04 and 05 for this nut but not the 06's apparently there was a problem with mine because after i tightend this nut it stoppped leaking.</end quote></div>
Can you tell me what size the clutch nut(s) are? I am going to clean my clutches and check my belt on Saturday, but I do not have the machine near me to check before hand. Any help you can give would be great.
lightninboy
May 16, 2021 09:52 PM
greg74
Sep 10, 2019 03:03 PM
TheHood
Jul 26, 2015 09:51 AM
trouttracker
Jul 20, 2015 11:54 AM
Unzzy66
Jul 11, 2015 10:01 PM
