2008 650 H1 EFI or not??
Old Nov 7, 2008 | 10:23 PM
sportsman rocks 's Avatar
Default 2008 650 H1 EFI or not??
Friend just bout 08 650 H1 and does not know jack about the arctic cat quads. I thought I read somewhere about a electric choke, is this atv carbureted or EFI?? Thanks Sean
Old Nov 8, 2008 | 01:38 PM
TAG's Avatar
TAG
The 650 H1 is a carb. Engine, the 550 H1 (Based on the 650 platform), 700 H1 & TCAT (951cc) H2 are all E.F.I. engines.
Old Nov 9, 2008 | 12:53 AM
Mudbug5's Avatar
had my 07 for about a year. no problems and plenty off ground clearence without doing any lift kits on it. carb is very easy if you need to rejet. IMO its a very good atv...
Old Nov 9, 2008 | 11:20 AM
Thanks for all your input, do you know if there is a electric choke on the 650H1, our maybe I was reading about some other quad.
Old Nov 9, 2008 | 11:34 AM
Mudbug5's Avatar
I'll check mine this afternoon and let u know..
Old Nov 9, 2008 | 02:29 PM
BlueRubie's Avatar
Yes arctic cat dose have carbs with auto eletronic chokes so its like having an EFI as you just turn the key hit the button and she fires up. . . but its still a carb. . .
But at the rate cat is advancing there technology on there sleds i have no doubt that soon Cat won't be making carburated engine in the future they have batteryless pull start EFI sleds so theres plenty of technology other there !
Tho i do see that CAT is putting more time and bucks into there sled than ATVs ! so who knows. . .
Mike D
Old Nov 10, 2008 | 01:29 AM
400crasher's Avatar
There is a primer lever on the right side of the carb as you are sitting on it. Its a small lever that you push down and it has a return spring. I have to use mine most of the time as I live at 8500 feet and its geting cold now. Mine wont start without 5-6 pumps. Also, I was told by a friend if it wont start right away, let off and give the choke a chance to engage, then try again.
Old Apr 30, 2022 | 10:05 PM
Shau's Avatar
Default Motor making a noise
I have a 650 artic cat it won't run turns over but sounds like something loose in the bottle end when it cranking
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
rgjackson
Sep 23, 2015 01:53 PM
Pissed off
Sep 21, 2015 02:33 PM
poutlaw525
Sep 9, 2015 03:19 AM
