plow mount bolts
Old Nov 24, 2008 | 09:42 PM
dirtmonkey's Avatar
Default plow mount bolts
trying to take stock bolts off at foot rest on each side to mount the plow but the nuts are turning with the bolts and I can't get up inside the drain hole in the steel tubing to put a wrench on the nuts. I've tried jamming screw drivers and such thru the tiny drain holes to try to wedge the nuts steady but no luck. Any ideas? Thanks. (10" snow coming tonite!)
Old Nov 25, 2008 | 08:58 AM
T-CAT Spd's Avatar
What kind of plow have got?
Old Nov 25, 2008 | 04:52 PM
dirtmonkey's Avatar
It's a Moose plow, but i think this could happen with any plow that mounts to a plate bolted to the Cat's foot rest.
Old Nov 25, 2008 | 05:53 PM
T-CAT Spd's Avatar
I'm not sure of the difference in chassis but it took about 5 minutes to put the harness on my T-CAT.
Old Nov 26, 2008 | 05:25 PM
swampyjunior's Avatar
I had the plow mount that slips between the foot rest and the frame and I did not like it. The one I have now bolts to the frame with 2 u-bolts near the foot rests. It is much easier to remove during the summer when I don't want it hanging down and getting bent.
If the bolts have broken loose you may need to cut the bolt, then drill or file out the drain hole larger so the nut can be removed. Then replace with the appropriate sized nut and bolt.
If you have a welder you might try tack welding the nut back in place and then try to remove the bolt.
That is about it.
SJ
Old Nov 27, 2008 | 10:55 AM
dirtmonkey's Avatar
appreciate the advice.
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
rcappie4
Sep 9, 2015 07:04 PM
