brakes
Old Dec 2, 2008 | 09:27 AM
mountainclimber's Avatar
Default brakes
i seems lately that my brakes seem spongy and the brake handle almost touches the grip on the handle bars. i think this menas my brakes are shot? if so what are good brakes to throw on there... stock?
Old Dec 2, 2008 | 01:02 PM
CatKrazy's Avatar
Default brakes
Yep, sounds like the pistons in your calipers are maxed, but there is not enough brake pad to keep tension on them. A loose axle nut will also cause this.
There are a lot of other companies that make them. I use a semi metalic brake.
I bought a complete set for 30 on ebay. What i do is take a cuttin wheel, and a dremel, and cut a X from top to bottom on each end of the new pads. You dont want to cut deep, just enough to allow the water and mud to have a place to run off. They will last just about 2 times longer.
Old Dec 2, 2008 | 06:38 PM
mudd011568's Avatar
Default brakes
I would agree with catkrazy I would take the wheels off check your pads replace any worn ones if you still have the same trouble i am afraid you are a victim of the master cylinder bypassing there is no rebuild for this available but I just got a quote for one today of $138.79 canadian so if you are in U.S. probably cheaper.
Old Dec 2, 2008 | 06:53 PM
swampyjunior's Avatar
Default brakes
Wheel bearings that are a little sloppy can cause this as well. But if this is the case it goes away if you pump the brake handle.
The wheel wobbles and pushes the plungers and brakes way back and you have to pump the brakes to make good solid contact.
Good suggestion on the groove CatKRazy I will have to try that one.
Old Dec 2, 2008 | 08:02 PM
CatKrazy's Avatar
Default brakes
<div class="FTQUOTE"><begin quote>Originally posted by: swampyjunior
Good suggestion on the groove CatKRazy I will have to try that one.</end quote></div>
NP, It works great!
Old Dec 3, 2008 | 02:16 PM
Default brakes
how deep do you do the cuts like 1/8"
Old Dec 3, 2008 | 02:30 PM
CatKrazy's Avatar
Default brakes
I dont go that deep.
Maybe a 1/16th. Its shallow but its deeper than a scribe. You just want a clean cut. It might be a qrt of a the thickness that the pads are.
Old Dec 4, 2008 | 10:15 PM
Mudbug5's Avatar
Default brakes
C K , Do u use oem pads or aftermarket?
Also the 1/16 cut on the pad, u ever redo the cut after pads are worn down some?
Old Dec 4, 2008 | 10:29 PM
CatKrazy's Avatar
Default brakes
I use aftermarket pads.
I have re-cut the lines before, but by the time it gets to that point, you dont realize it because its been so long. The next thing you know, you need new pads.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
