2005 artic cat 400 stalling out
Old Feb 12, 2009 | 02:47 PM
yooper35's Avatar
Default 2005 artic cat 400 stalling out
been having a problem with my 2005 artic cat 400 stalling out. It seems when I drive it for about 10 to 20 miles it will start losing power then backfiring then shutting down. I can restart the engine right away, but after it starts doing this i can only go for about 1/2 mile at a time until the same thing starts happening. If I let the artic cat cool down for awhile it seems to run fine until it starts happening again.
some things that i have done is change the spark plug and put fresh gas in, I've also drained the carb a few times, but its still happening
any help would be appreciated thanks
yooper35
Old Feb 12, 2009 | 02:56 PM
cragle1's Avatar
Yooper, I would first check the vent hose from the gas tank. Make sure it is not pinched or clogged. I would then look at your coil. This is probably your problem.
Old Feb 19, 2009 | 11:54 AM
SoCalHavoc's Avatar
I had the exact same problem on my '99 Arctic Cat 250 2x4. I suggest you do what I did, and take a multimeter to the battery when it is off (should read 12V), and then when it is running (should be around 14V). If it isn't 14 volts when it is running, take off the plastics, disconnect and clean your grounds, and then trace the wires as far as you can. Make sure you wiggle them around with your hands when you do, but have the bike off so you don't get zapped. My problem wound up being at the voltage regulator, there was w wire that had corroded away in one of the connectors. If you don't have the book, just go online to a parts place where you can look up part numbers, and they should have exploded views of every system to help you trace it out. If you can't figure it out that way, it might be the stator (which unless you are a professional mechanic, you might want to think about taking to the shop).
All of that popping and sputtering is probably just your battery dying on you because it can't charge itself back up as you are riding.
Best of luck, and hope it is a cheap and easy fix.
Old Feb 19, 2009 | 11:59 AM
Turfguy's Avatar
Never mind, was going to suggest bad gas till I read the clicking starter thing. Sorry
Old Mar 4, 2009 | 09:23 PM
KaylaCat's Avatar
yooper35,
So how did it work out.
I have the same problem on my 2005 ac 500 tbx[img]i/expressions/face-icon-small-confused.gif[/img]
I changed the fuel, drained the carb, checked the vent hoses, checked the connections.
The next step is pull the carb.
Old Mar 5, 2009 | 07:39 AM
cragle1's Avatar
You should also check the coil as they will develope a small crack and as your machine heats up, the crack will get larger until it backfires and quits. Once it cools down, it will start again and run fine.
Pehter
Oct 3, 2024 11:00 PM
salixair
Nov 3, 2015 08:25 AM
kodiacrunner
Oct 4, 2015 11:52 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Brandon400
Sep 5, 2015 08:44 PM
