1999 ARCTIC CAT 250 2 X 4 IDLING PROBLEM
Old Mar 2, 2009 | 10:42 AM
doorgod's Avatar
Default 1999 ARCTIC CAT 250 2 X 4 IDLING PROBLEM
I have a 1999 Arctic Cat 250 2 x4 ATV and when a start using it, it idles fine for a while then after it starts warming up, it starts to idle faster and faster. is this a intake gasket issue maybe? And if so can anybody explain the repair briefly as I believe I can do it if its not too complicated. Thankyou.
Old Mar 2, 2009 | 11:17 AM
rockout's Avatar
it is possible. try lightly spraying some carb spray around the intake and gasket area. listen for idle speed changes. check bolt tightness too.
Old Mar 2, 2009 | 11:20 AM
doorgod's Avatar
Ok thanks. Any other ideas in case that doesn't change idle speed. should I do that when I first start it or wait until idle starts to increase.
Old Mar 2, 2009 | 11:27 AM
rockout's Avatar
wait until it acts up. did the problem just start overnight? been slowly acting up? did anything happen to make this problem (backfire/running rough)?
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
