Need help please!
Old Apr 1, 2009 | 08:47 PM
maxlacy's Avatar
Default Need help please!
So I'm having problems with my 97 BearCat 454cc. 1st problem: What's the correct compression range for this atv? 2nd problem: Every time I start this quad the 30amp fuse in the (starter relay?) towards the back of the quad wants to blow. Any ideas why?
Old Apr 2, 2009 | 11:03 PM
swampyjunior's Avatar
Not sure about the compression I'll have to check on that.
30amp fuse popping is a result of a short. When I had a similar issue with my TRV. Mine would pop when I turned the key to the ON position. I took the instrument pod a part and found a wire going to the ignition key that had been pinched when it was built. Once I traced it down and patched it up no more problems. So if it were mine, I would follow the wires from the 30amp fuse to the ignition and where ever else it goes looking for a short.
SJ
