RYANS ANSWER ON 589's
As I sated before with my 589's 27 inch with two
people riding, you will rub your muffler a little
on rough conditions.Also if you jump the machine
even a small jump,the front will rub.My 589's are not from ITP,as I read here earlier that the new ITP version are even taller.So if you do not want to put in a spring spacer(a little rougher ride),or a lift kit,then go with a 26inch tire.
KEEP THE RUBBER SIDE DOWN
OUT
OUT
