leaky rear diff: no problem said dealer
Old Feb 19, 2001 | 04:44 PM
TEXASCAT's Avatar
on my post dealing with synthetic oil i alluded to my rear diff leaking. my dealer told me that the leak was not serious enough to worry about as long as it didn't make a puddle after it was parked. i rode it hard this past weekend and no puddle showed up. the dealer said to keep an eye on it and keep adding oil whenever needed and if something goes wrong ac will replace it free.
texascat
Old Feb 19, 2001 | 09:21 PM
shmoky's Avatar
TEXASCAT:
Great dealer service. Sounds like my dealer too. This is one of the reasons I bought AC. Only 6 mo. warranty (i bought in fall and wouldn't get much use thru the winter) and they said they would "look after me" for 1 year.
Old Feb 20, 2001 | 07:22 AM
roys's Avatar
No offence to your dealer but if you had a oil leak under your rear-dif. of a new truck,I bet you would want it fixed.I had the same leak.It started at 600miles,only a little at first.I found that if you would ride on long(3 to 4 miles)
WOT,then more of a top up would be required.AS you said your dealer would take care of you ,I hope that it means the possibility of a new rear diff,because if oil is getting out then dirt /crud is getting in.Since I had mine replaced I had no top-up required and I have over 600 miles on it with the new seals.
KEEP THE RUBBER SIDE DOWN
OUT
Old Feb 21, 2001 | 12:44 AM
TEXASCAT's Avatar
actually, much to my amazement, i removed the level plug and found that no more oil leaked out even after a hard riding weekend like i had. i am using a 80w-90 marine lower unit gear oil and it works flawlessly.
thanks.
texascat
Old Feb 21, 2001 | 07:16 AM
roys's Avatar
It is a good sign when you do not have to add any oil to your rear diff.There is a little amount of grease that is behind the rear drive-shaft seal,I was told that it is put there when the machine is manufactured.Some of this grease may squeeze out when good and warm,dut no cause for alarm,because it is there mainly for new running break-in period.
OUT
RticKwad
12
Jul 19, 2015 12:22 AM
Land_shark1
Jul 10, 2015 12:53 AM
scaldwellk
Jun 19, 2015 05:08 PM
hoopduerr
Jun 1, 2015 08:22 PM
blaze_master
May 26, 2015 11:18 AM
