Need help! oil filter problem?
Old Apr 17, 2010 | 08:30 AM
1771's Avatar
Default Need help! oil filter problem?
2000 artic cat 300 4x4 green.
possible problem with new filter:
*filter does not slide onto inlet shaft, it butts to it
*the old one came off same way
*definetly have the correct filter (matches old one)
*o ring does not appear to serve any purpose
*manual is not to clear on this just says to make sure spring is between filter and cover plate
*i'm not convinced the filter hole will line up correctly with inlet on shaft
This make sense? any help would be greatly appreciated thanks!
lightninboy
May 16, 2021 09:52 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:43 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
