Rear Brakes Artic Cat 500
Old Jun 24, 2010 | 01:12 PM
Supervisor 4's Avatar
Default Rear Brakes Artic Cat 500
Has anyone had luck repairing the rear master cylinder or should I just replace it.
Old Jun 27, 2010 | 10:40 AM
swampyjunior's Avatar
I am pretty sure they do not make rebuild kits for the master cylinders that AC uses. I am assuming your machine is new enough that it is the one with a master cylinder for the rear foot brake? as well as the front hand brake?
I am not sure if you have looked for it but there was a posting on here from someone who had lots of issues with the master cylinders and he converted it over to a master cylinder off a street bike. Which he could get a rebuild kit for if he needed it.
Try searching this site for it. Also, check around for a replacement. If I remember right they are pretty spendy but if I was going to spend the $ I may look at converting it to one that can be rebuilt. Especially if it is about the same amount of $
Hope this helps and welcome to the forum.
Swampy
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
timster911
Jul 13, 2015 01:57 PM
