spark issue with 04 youth 90
Old Jun 25, 2010 | 06:50 PM
hydro's Avatar
Default spark issue with 04 youth 90
Does any have any wiring diagrams for this model any help would be great. I have no spark and I need a diagram to check it out.
Old Jun 27, 2010 | 10:47 AM
swampyjunior's Avatar
I have no wiring diagram but the last youth model I fixed with no spark I followed the juice from the battery to the CDI to the starter and the plug. I traced the wires with a volt meter from the battery.
As you have already done I started by checking for loose or corroded connections and making sure the battery was charged. Then check the neutral sensor, ignition key and ON/OFF switch.
The Youth models are fairly basic wiring wise. If your dealer is a good one he may print you a wiring diagram.
Swampy
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
Jul 11, 2015 11:52 AM
