arctic cat 375
Old Aug 11, 2010 | 01:26 PM
arctic cat 375's Avatar
Default arctic cat 375
i have an 02 arctic cat 375 4x4 that wont start with the push buuton. I have checked for power to the switch, changed solenoid, checked starter and it still wont start with the switch. I can start it with a screwdriver by touching the solenoid. There is now power from the 1 wire on the solenoid to the top of the starter. I changed that wire and still no power. What am i missing?
Old Aug 13, 2010 | 04:22 PM
cdn pete's Avatar
Did you check the fuse inside right rear fender?Iused to remove this fuse as security precaution...it will not start without the fuse.
Old Aug 14, 2010 | 10:26 AM
yea i checked the fuse i even replaced the solenoid.
Old Aug 14, 2010 | 12:20 PM
cdn pete's Avatar
There is a neutral starting relay,but dont know where it is physically on machine.For future consideration,there is a 2 wire plug high up along the steering column when if loose will prevent "start in gear feature" but should still start in neutral.
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
