2006 400 carb adjustments
you should have remembered that when you initially cleaned the carb but i think the fuel mixture should be screw it all the way in and crank it out 1 3/4 turns and it should put in you the pickle barrel. you will be able to tell how it runs if you need to take it 1/8 of a turn one way or another. and as far as the float it should be pre set but if you want to set it i was always showen that hook up to the fuel line and blow in there and the float should be perfectly level when you can't blow in it anymore.
2006, 250, 400, 650, adjustment, arctic, articat, artticcat, carb, carbarator, carburator, carburetor, cat, quad, setting, tuning, v2
