Mud pro 1000 vs thundercat 1000??
Old Jan 3, 2011 | 09:12 AM
buck80mph's Avatar
Question Mud pro 1000 vs thundercat 1000??
Will the mud pro 1000 power wheelie on flat dry ground?(the long wheel base must affect this)
Are the axles on the mud pro more heavy duty than the t-cat?
I'm not a mud pit racer. I'm more of a trail and mud hole rider. My buddies and I also cut up on dry ground in pastures riding wheelies ,cutting do-nuts and drag racing each other. With this being the case. Would I be better off buying the t-cat 1000 and installing aftermarket snorkels and tires?
How does the ac 1000 compare in power to the can-am 800?
Old Jan 3, 2011 | 09:25 AM
TLC's Avatar
TLC
Polaris 850______69.06 hp
Can Am 800 R____67.05 hp (updated 2/13 to 70.5 hp)
AC 1000_________65.84 hp
Can Am 800______61.7 hp
Can Am 650______55.4 hp
Brute 750 Carb____50.1 hp
Brute 750 EFI_____49.8 hp
King Quad 750____49.6 hp
AC Mud Pro_______49.06 hp
King 700_________48.5 hp
Polaris 800_______48.3 hp
Brute 650 I________46.3 hp
Grizzly 700________45.6 hp
Polaris 700_______44.3 hp
AC 700 H1_______41.4 hp
AC 700__________41.4 hp
Brute 650 ________41.4 hp (solid axle)
Grizzly 660_______40.9 hp
Can Am 500______40.4 hp
AC 650 H1_______39.3 hp
Rincon 680_______38.5 hp
Old Jan 3, 2011 | 09:43 AM
buck80mph's Avatar
Thank you! Very good info.
Old Jan 6, 2011 | 06:16 AM
buck80mph's Avatar
Come on guys!
No one else has any opinions?
Old Jan 6, 2011 | 10:50 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
The Mud Pro would be my choice....why go aftermarket when there is a factory set up, ESPECIALLY when the factory gears are already properly set up for large tires on the MudPro?
If you're buying a 4x4 to pull wheelies, get a Scrambler or Can-am...if you're looking to be the guy everyone else envies at the mudhole, get the mudpro
Old Jan 7, 2011 | 10:14 AM
buck80mph's Avatar
I want both LOL!!
Old Jan 10, 2011 | 11:36 AM
buck80mph's Avatar
Not much activity here!
Old Jan 11, 2011 | 05:31 PM
AC Rider's Avatar
i would go with the t-cat because the mud pro is mostly just ment for mud bogging......let us no what u decide
Old Jan 23, 2011 | 07:01 PM
savageman69's Avatar
Personally id buy a thundercat....People above who say the mp1000 is geared more for the bigger tires are flat out wrong, the mp1000 and tcat both have 3.1 ratio diffs. Just the mudpro is clutched, by using different secondary helix and longer primary collar is longer. However i dont like the long chassis nor think that its worth the extra from a tcat to get zillas and snorkels and a bit of clutching.
Old Jan 25, 2011 | 09:28 PM
No Ruts, No Glory
not really flat out wrong, just a year model late...the TCat had 4.0 gears originally.
