Blank Display
Old Jan 29, 2011 | 07:07 AM
taribana's Avatar
Default Blank Display
I have a 2008 Arctic Cat 650i. The display lights up but is blank. I've tried the connections but find nothing loose. I'd appreciate any advise.
Old Jan 29, 2011 | 09:35 AM
cupsz71's Avatar
Cool
Common issue with CATS but a relatively simple fix:
-PULL your battery cables off for about 5 min
-PULL your 30amp accessory fuse (green) for the same amt of time.
reconnect and your should be good to go.
This basically re-sets your ECM. For whatever reason it can loose it's "contact" with the gauge pod. Most likey as a result of a low battery.....and when you crank it.....dead gauge.
Old Jan 29, 2011 | 11:24 AM
taribana's Avatar
Default Cat Display
Bingo. I live 90 miles from the nearest cat dealer. I called two service departments. One said they replace a lot of displays. The other only said that if I took it in they could sure fix it. Thank you. I hope I have an oportunity to do something for you someday.
Old Jan 29, 2011 | 02:25 PM
cupsz71's Avatar
NP!
95wolv
Sep 27, 2024 12:00 PM
Jeff Roper
Sep 21, 2015 02:11 PM
patrick.oc123
Sep 15, 2015 02:45 PM
Bigtwin700
Sep 10, 2015 10:46 PM
rawbdiggity
Sep 7, 2015 12:05 PM
