05 artic cat 650 v twin belt light, limp mode, HELP
atv was in limp mode, belt switch unpluged by accident, used the jumper from artic cat dealer, followed dircetions, but light will not go off. need any ideas
Give this a Try
"the reset procedure is similar to 650 700. Unplug 2 pin conector going to belt switch. Unplug black conector under seat , unplug white conector beside it ( white plug is a reset plug which has no wires conected to it from machine) Plug reset plug into black plug turn key to on , turn off. plug everything back to stock. You are done."
1) remove seat, unplug black and grey 4-pin connectors
2) swap plugs, grey to black and black to grey
3) turn on ignition switch, belt light should be flashing quickly
4) disconnect 2-pin belt switch above torque converter cover, belt light should be flashing slowly
5) let flash for at least 5 seconds
6) turn off ignition switch
7) reconnect 4-pin connectors black to black and grey to grey, reconnect 2-pin belt switch
8) turn on ignition switch to confirm belt light is out
Imagine yourself 5 miles down Ninilchik beach (alaska). You just ran through a small (3"deep) falls creek and the tide is coming up like a freight train. Some points of land on the bluffs crop way out there. When it did arrive, I would lose my 04 AC 650 v twin.
The reset light is blinking and I can only make 7-8 mph at best. I thought of everything I could and checked. But, then decided to continue and try to make it. And I did by the skin of my teeth. All the way home (250 miles), I was sure something was trashed. Then I read your article. You, my firiend are awesome. Will try it tomorrow. Thanks
fordfaithful21
Dec 7, 2015 05:52 PM
Steeldon
Sep 9, 2015 09:38 AM
Logan Collins
Sep 5, 2015 08:03 PM
