650 2wd 4wd switch
Old Dec 13, 2011 | 09:26 PM
Turnducky's Avatar
Default 650 2wd 4wd switch
I have not drove my arctic cat 650 v twin for a couple of years, i decided to take it apart and paint frame, after doing so and putting it back together when i turn the key all the way on i can shift from 2wd to 4wd then i turn the key to the acc side it goes back to 4wd automatically and i can not shift it to 2wd. is this normal, I dont remember it like that but its been awhile please help thanks.
Old Dec 14, 2011 | 07:58 AM
dodgeman01364's Avatar
That doesnt sound normal, but I'm not sure what would cause that problem
Old Dec 14, 2011 | 09:09 AM
Turnducky's Avatar
ok, just out curiosity i cut the plug out and wired each wire with separate plugs, if i leave one ground wire off the it does not go back to 4wd nor does not switch when the key is turned to the acc position but works fine when key is turned all the way on.
Old Dec 17, 2011 | 01:48 PM
leaving a ground wire off means your not completeing the circuit, just means the problem is there still
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
toonces
Sep 5, 2015 01:14 PM
