98 AC 300 4x4 purchase
Old Jan 17, 2013 | 12:52 PM
gfdeputy2's Avatar
Default 98 AC 300 4x4 purchase
Hello everyone new member here
I am looking to purchase a 1998 arctic cat 300 4x4
this is what he stated to me :
nice shape runs but has a small issue maybe the carb
Starts spuddering after it warms up n shuts off sometimes but starts right back up
My question is I have seen a lot with the same issue everyon always say's clean Carb but I never see whether or not this cured the problem is it usually the Carb or is it something else
would hate it to be something expensive like a CDI
he is selling this ATV just over my max price range but the best looking one by far but will not have much extra cash to put into it
Thanks in advance
Here is a pic
Old Jan 17, 2013 | 01:37 PM
papahouse's Avatar
Cleaning the card fixes most of the issues you've read. Gasoline varnishes over time and clogs the jets if they are not run often.
Old Jan 17, 2013 | 02:40 PM
gfdeputy2's Avatar
thanks I wasn't sure if this was the actual cause of these issues or not I guess I may take the chance on it
Old Jan 17, 2013 | 05:47 PM
TLC's Avatar
TLC
Will not be anything exspensive,CDIs are like light bulbs they work or they do not. Most likely a carb cleaning.
I have clean carbs on machines I though where running pretty good and they started up nicer after a carb cleaning.
Change the spark plug and clean the air filter while your at it.
Nice shape and AC uses reliable Suzuki motors in those. Same 280cc motor used in the 300 KQ for over 10 years. http://www.atvreviewnetwork.com/enth...icle2=27&go=Go
Old Jan 17, 2013 | 07:31 PM
Lilray76's Avatar
My cat did the exact same thing and it was the spark plug.
Old Jan 18, 2013 | 05:07 AM
gfdeputy2's Avatar
Thanks everyone I have a couple to look at but so far this is the best looking one
Old Jan 19, 2013 | 06:22 PM
gfdeputy2's Avatar
well I ended up getting a Honda Rancher ES
Old Jan 20, 2013 | 10:39 PM
Cummins Driver's Avatar
You will be happy with the Rancher.
Just out of curiosity, what were they asking for the Arctic Cat? My father in law had a 300 4x4 AC for a little bit and it was a good machine. Wouldnt mind to have one myself.
Old Jan 21, 2013 | 05:08 AM
gfdeputy2's Avatar
$1050 didn't get to see it personally but body wise the arctic cat looks like it is in a little better condition but no extras
The Rancher is an 01 with 2000 Lb winch new titan xt489 tires ITP rims 1 1/2" lift (I just removed due to front axles clunking) & plow mount
Old Jan 21, 2013 | 09:28 AM
TLC's Avatar
TLC
The Arctic Cat had a few extras the Ranch does not.
Low range
Super low range
Diff lock true 4wd.
Disc brakes front/ back, all hydraulic
IRS rear suspension.
OHC motor.
Full size chassis.
selectable 2wd/4wd
larger gas tank.
