'07 650H1 back tires spinning
Old Feb 9, 2013 | 01:19 PM
Bowerbirdgirl's Avatar
Default '07 650H1 back tires spinning
We just changed the cam chain and some related parts. After putting everything back together... the thing wants to take off as soon as you turn it on. When (while on the ground riding) you apply the brakes... the front brakes work, but the back tires keeping spinning. They will not stop. You also have to turn it off now to change gear.
We figure something is wrong in the clutch box and have taken the cover back off. Any suggestions on what could be causing this and what we should be looking for?
Thanks in advance.
Old Apr 7, 2013 | 10:55 PM
JBLAZE's Avatar
Is the idle turned up to high?
Old Apr 8, 2013 | 09:42 PM
Cummins Driver's Avatar
Sounds like something on the primary clutch (the one on the engines crankshaft) is not right. Or it could also be the idle too high like he mentioned, but I would think that would be pretty noticeable.
txkevin
Sep 21, 2015 02:02 PM
Mphillips
Jul 29, 2015 08:53 PM
ragewraps
May 27, 2015 09:25 AM
ragewraps
May 27, 2015 08:07 AM
MrElussive
Nov 10, 2000 05:05 PM
