Brake Lever!
I have a 2003 Arctic cat 500. The front brake lever doesn't return out all the way and in this case my brake light tends to stay on. The front brakes work ok but is there a spring in the master cylinder that needs to be replaced? thanks Tom.
Should be a spring on the master cylinder piston,but doesn't show a rebuild kit.M/C plunger may be sticking? Plus check that the bolt and nut aren't too tight holding the lever. Hopefully others will come along that may be able to help better. http://www.alpha-sports.com/
oliveiracarlos
Sep 7, 2015 03:39 AM
