Back firing AC
Old Dec 31, 2013 | 08:22 AM
beav650's Avatar
Default Back firing AC
When my 2010 AC 650 is warm up and I shut it off, it sometimes back fires. Can someone tell me what causes it too back fire.
Old Dec 31, 2013 | 05:53 PM
papa hogg scoot's Avatar
Loved
Community Favorite
CountryCat.com
Old Dec 31, 2013 | 06:04 PM
Loved
Community Favorite
item #16 is fuel mixture screw alot of atv are set pretty lean from factory to pass the emissions for goverment..an sometime this can cause an backfire..If you want try this test out the redneck way it could tell if this is your atv problem...let atv get normal temp while idling put hand about 2 to 3 inches from end on exhaust an if it burns or stings your hand then the mixture screw or [PILOT SCREW} is correct name but alot of time this screw has welch plug[plug or limiter cap] over the screw head so cant be readjusted..may have to remove plug an opened up screw bout half to an full counterclockwise turn then recap back..Also if hand doesnt stinged or hot the could have baffle in muffler burning out an sometimes the baffle block exhaust from existing muffler an back fires to move baffle so can exhaust vapors out, If atv has an high idle sometimes this could cause an lean fuel burn an cause an backfire.
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
