2001 arctic cat 400 4x4
Old Jan 9, 2015 | 12:03 AM
muggsie's Avatar
Default 2001 arctic cat 400 4x4
hello, i need some help please, when i got this arctic cat 400 4x4 green atv it did not run, so i went through it and pretty much replaced most of the parts trying to trouble shoot the problem,long story short,it was the timing chain ,it was broke, so i replaced it and you know what that consists of, but got it all back together , got her started like three times and i was leaking oil from the crank case side so replaced the gasket again and it stopped leaking but know it wont start, it turns over and almost starts and like back fired a couple times man it so close to starting and im stumped now, please help me out if ya can, thank you very much in advance,
Old Jan 10, 2015 | 06:19 PM
Greying's Avatar
if it was me and going from my experience I would suggest 2 things. the carb or the timing.
Old Jan 11, 2015 | 09:53 AM
Zrock's Avatar
Super Quad Patrol
Timming
Old Jan 11, 2015 | 01:09 PM
muggsie's Avatar
ok thank you ,i did tack off carb and it was clogged up one jet ,witch i was leaning that way anyway but this has got me puzzled,every time i tuen on the gas the primer housing is like shooting gas out of the hole that on the housing,and when i go to prime it the gas almost shoots across the room what in the world is going on with this thing, please help me with this one question and i should be good then thanks man
Old Jan 11, 2015 | 02:01 PM
muggsie's Avatar
0k so i cleaned the carb ,it was dirty jets were clogged, now when i turn on the gas, at the primer housing gas is coming out of the hole
that's in the housing ,and when i try to prime it the gas shoots across the dang room ,lol first time got it right in the eye,but why is this occurring and how do i fix it it does stop when i turn off gas
Old Jan 12, 2015 | 07:27 AM
Greying's Avatar
Keihin 32CVK Disassembly
Check this out. It is a really good carb repair pictorial
Old Jan 28, 2015 | 08:46 PM
muggsie's Avatar
sorry it took so long to get back to you guys, i got it running but it seems to have very little power,in high and or low gears,it will not idle on it own either,ive cleaned the carb three times now because that is where im being told my problems are, what else could be the problem ?
Old Jan 29, 2015 | 06:54 AM
Just cleaning a carb may not help if it has worn parts. A carb kit plus a primer repair kit may solve your problems. http://www.ebay.com/itm/ARCTIC-CAT-ATV-250-300-375-400-500-CARBURETOR-CHOKE-PLUNGER-STARTER-KIT-/151202276463?pt=Motorcycles_Parts_Accessories&hash=item23345ba46f&vxp=mtr
Old Jan 29, 2015 | 07:07 AM
Greying's Avatar
is it bogging down? Maybe your timing is off? You just might need a carb kit. Maybe you need to bring it to a mechanic. If my son was not a mechanic, my bike would likely be in the shop. I am tearing the top end apart a little at a time because it is hard on the fingers at -30. I have no heat in my shop. I will replace the valve seals and rings. I was having some issues with smoking and overheating and found the valves were not set properly. The more I poke around, the more I find little stuff wrong and signs that whoever serviced this bike in the past absolutely did not know what they were doing. Therein are some reasons why mine was not really running right. I am also looking for a fan to install and help in the cooling dept.
Did you ever replace the gas or check the gas tank? Sometimes you just need another pair of eyes.
Good luck
Old Jan 31, 2015 | 09:01 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Im not sure if the 2001 model is included but I know 2002 to 2006 have glued on flywheel magnets an if they come unglued it will changed the ignition timing,,I have had serveral 2002 to 2006 400 suzuki and 400 arctic cat which is the same engine on most...May want to take down to flywheel an look at the magnets an see if they all are spaced out the same distance if they have moved the suzuki flywheel is same part an save some money an make sure new flywheel has machined magnets into metal flywheel.....IF flywheel ok then get back with us here an we help with next step
Customer Service #1
May 15, 2020 08:46 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
35dodge
Sep 29, 2015 09:40 AM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
