366 electical flickering
Old Feb 4, 2015 | 08:29 PM
irish88's Avatar
Default 366 electical flickering
ok I had this used acrtic cat366 for a week now. just tonight finish up clearing the driveway. noticed the headlights and panel flickering. if I hit the throttle, it clears up. I am planning to take back for warrtiy work done.. but would like to know what cause it.
Old Feb 4, 2015 | 08:45 PM
Check charging back the battery while at an idle or slightly above. Should be around 14 volts. If lower,could be sucking the battery down and causing voltage to fluctuate on the lights. Can be a faulty regulator causing this,a sulfated battery unable to hold a charge especially if the regulator shows to be charging or can even happen if too many accessories are hooked up at the same time that the system can't keep up with the electrical demand.
Old Feb 5, 2015 | 07:39 PM
irish88's Avatar
thanks for the tip. it was dead this morning.. had to jump start. then ran for awhile,, it died.. took it to shop for under war. work. I wont get it back next fri when I am off.. I didn't have my muilt meter with me today.. left at my job site.
Jr Wagner
Aug 21, 2015 07:56 PM
chop
Sep 23, 2001 10:52 PM
hot_shoe_cv
Nov 10, 2000 09:50 PM
ScoobyDFW
Apr 26, 2000 01:54 PM
