Carb issue!
Old Feb 6, 2019 | 06:34 PM
michaelperkins69's Avatar
Default Carb issue!
Hi, i bought an 2003 arctic cat 400 4x4 non running.vi bought a carb rebuild kit and was rebuilding it today when i ran into an issue the float needle is smaller than the hole so i checked the old one and it was also smaller. Any ideas the carb is a keihin cvk 38fe sgj . i don't know if it's the original one or not but figured it was since it's oem and not Chinese.
Old Feb 7, 2019 | 11:23 AM
DirtDevil101's Avatar
Just to clarify...when you say float needle are you talking about the float bowl needle that rises as the bowl fills up and shuts off the fuel flow? If so...the needle (or plunger) is supposed to move up into the brass hole but then it rubber top (usually) plugs up the smaller hole inside...
Old Feb 7, 2019 | 11:00 PM
Default Carb issue
Yes that's what I'm talking about the brass hole is way larger than the plunger or float valve it's crazy I've rebuilt plenty of carbs but i haven't ever ran into this issue any ideas why the brass hole i this carb is larger?
Old Feb 8, 2019 | 07:24 AM
Tanker_01's Avatar
is there a smaller hole recessed into the brass piece that the float bowl needle is sealing against? Have you done a float needle seal check? When you turn on the fuel on and the bowl fills is it pissing fuel out of the overflow drain?
Old Feb 8, 2019 | 08:24 AM
Default Carb issue
Yes it will not stay sealed it ***** the float valve to the side because the opening is too big.
Old Feb 8, 2019 | 08:25 AM
Old Feb 8, 2019 | 08:29 AM
Old Feb 8, 2019 | 08:32 AM
Tanker_01's Avatar
Looks like you may be missing a piece that is supposed to go into there that the float needle is supposed to seal against. Check a parts breakdown print and take inventory.
Old Feb 8, 2019 | 08:41 AM
Default Carb issue
Hmmm didn't think about that I'll check thanks
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Thespazardman
Jun 25, 2002 12:14 AM
johndjmix
Jun 6, 2000 06:46 AM
