Zilla won't stay running (Carb issue?)
Old Jun 24, 2002 | 12:56 AM
Thespazardman's Avatar
I have an 88 Zilla (.100 over, cool head, 6 inch swingarm extension, etc etc) and the darn thing won't stay running without pumping the throttle. It's especially bad when it's cold, but then when I finally get it warm, it will only stay alive for about 20 seconds, before it dies (unless you push the throttle, ie pump the gas, again). The idle speed seems fine (until it dies). Perhaps I need to rebuild the carb? I'm quite sure it's a KEIHIN 38.5. Perhaps I'm just running it too rich? The plug seemed to look fine tho.
HELP is appreciated.
Thanks.
Thespazardman
Old Jun 24, 2002 | 05:08 AM
TRX250EXER's Avatar
sounds like you need a different pilot jet. or maybe adjust something else. does it run good otherwise. oh... didnt suzuki use mikuni carbs?? not keihin
Old Jun 24, 2002 | 05:19 PM
Mr350X's Avatar
Why do you want your Zilla to idle for 20 seconds?!
2 strokes dont like to idle. They will load up, as you probably know.
My Zilla (that runs perfectly) will idle for a few seconds and then eventually die. This is normal for a 2 stroke, as far as Im concerned.
If your Zilla is going to idle for more than 5-10 seconds, just kill it and give it that few seconds to cool alittle bit.
Old Jun 25, 2002 | 12:14 AM
chinkapin
Jul 14, 2016 06:58 AM
wannabe32
Jul 7, 2015 11:30 AM
Dabears1983
Jun 16, 2015 12:17 PM
robj
Jun 15, 2015 08:45 PM
jayking232003
Jun 9, 2015 02:54 PM
