Bearcat troubles
Old Apr 23, 2020 | 06:05 PM
Retired now's Avatar
Default Bearcat troubles
I have a 97 Arctic Cat Bearcat 454. It won't run at high rpm unless I have the ignition switch turned to the lights on position, or if I pull the brake hand lever. If it's running bad and I pull the brake lever, it smooths right out and runs fine. Also, if it's running bad and I turn the ignition switch to the lights on position, it smooths right out and works fine. Please help
Old Feb 1, 2021 | 09:20 PM
Tristan Roberts's Avatar
Default Bearcat 454 missing
I am working on 96 Arctic cat 454 bearcat wondering if anyone ever figured out why the pressing the brake or key switch in second position affected how the engine runs
russ2952
1) Engine problems..
Jun 29, 2010 10:22 PM
rwea14
Jan 16, 2010 01:21 PM
tncrom
Jul 16, 2008 05:08 PM
DAFUZZ
May 3, 2004 01:10 AM
Cannitor
Jul 15, 2002 04:00 PM
