1998 arctic cat 500 4x4 won’t shift
Old Oct 12, 2022 | 01:22 PM
Snowpro81's Avatar
Default 1998 arctic cat 500 4x4 won’t shift
Hi guys, I have an old 500 manual that won’t shift. It’s stuck in third but it still drives normal no noises or anything. If I push the shifter up or down it’ll shut the third gear light off but won’t shift. I adjusted the clutch but it still won’t shift. Any ideas? It does it in both low range and high range. Thank you.
-Tim
Old Jan 6, 2023 | 08:13 AM
Snowpro81's Avatar
Default Response to myself lol
I got the clutch cover off and it turns out there was a spring missing. It went to the two arms with holes on the bottom left.
chriskat1100
ATC 3-Wheelers
Aug 7, 2007 12:18 AM
mudmanatv4x4
May 13, 2002 07:09 AM
